try this
delete the widget, then settings > apps > all > weather > clear data > restart your phone
re-add the widget > tap to configure > do NOT enter the city, click on use current location
Thanks I have done this. I will let you know if I have any problems, I won't be travelling until tomorrow.
I have the Z1 and I was able to recreate your issue, and that suggestion above solved the issue for me, let us know if it works out for you
Should I add the widget to stamina mode whitelist if possible? I don't see this being a problem though as I mentioned earlier, the temp and time refreshed update just not the location.
Thanks
That could also be another issue, do add it to the whitelist
I'm sorry to hear that and you GPS its on and all those permisions are on too, turn off stamina mode and check again
At the moment, there is no support in the preinstalled weather widget to automatically update your location. You have to manually set your location.
