Wi-Fi problems persist Xperia E4
xgpc3u
the wireless device E4 continuing my offline but it seems that even it was connected without receiving data, I have to reboot for the phone can reconnect the modem but only for a while because it is switched off again, what I can do?, It is issues with my phone or the software?, and e tested with another modem but the problem persists. I guess it's a software problems, because I found that if I turn off the option that says ''Search always available (Allow Google location service and other applications seeking network while Wi-Fi is disabled)'' it solves part of the problem no longer need to restart the phone, just turn off the Wi-Fi and turn on again and it connects smoothly again but only for a while and again fails
Please what is the solution?
sorry for my bad English
13 REPLIES 13
Uliwooly
xgpc3u
yes, but let us be realistic the restart or turn off the Wi-Fi It is not a viable solution.
Uliwooly
@xgpc3u
Don't create duplicate posts, contact Sony directly
http://support.sonymobile.com/global-en/contactUs/
and report your issue,  I understand that it's frustrating.
xgpc3u
sorry for create duplicate posts
thanks
Uliwooly
@xgpc3u
Anytime
xgpc3u
Hi, I see you have a solution to the problem in video playback, but what about the disconnection of Wi-Fi, It took days asking sony but no response, I have two problems, cahe files in the internal memory (the update will fix it?) and the Wi-Fi disconnect, seems to be connected but no connection and you have to reboot your phone for it to reconnect.
I don't know software problem or I have to take my phone to the technical service?
sorry for my English
thazm16
Same happens for me... strange issue
lopac42
Hi
I have the same problem with my E4 but only with my wifi at home .
anonymous1
Hi i have a sony E4. My wifi keeps disconnecting after a while and my stamina modes are switched off and my advanced wifi settings are correct. Ive tried all the suggestions. Please help.
