WIFI 5 ghz missing conection
Liudvikas
Yuneec CGO3 video camera
Xperia z2 connect but in 10 s lost, connect and lost......
Try with friends xperia z3 and z5 works good.
Have any ideas
Android 6.0.1
kernel version 23.5.A.0.575
With regards
Liudvikas
6 REPLIES 6
Phy
Legend
Legend
Do you experience the same in safe mode?
How to boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
How to boot on safe mode on Lollipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Liudvikas
Thanks for qiuck response, but in Safe Mode result is exactly the same
With regards
Liudvikas
allsystemsmaste
Same situation, it disconnects from different routers at random times and even being next to the modem/router.
Liudvikas
testing with colleagues Sony xperia z2, result same as with my phone
seems is technical defect of sony, next generation z3, z5 works properly
With regards...:(
Liudvikas
after update Jun 28 2016, version 23.5.A.1.291 all working ...:)
Thanks
With regards
Liudvikas
DanijelQ
My WiFi working, but when I open an application, it says Can't connect right now.
It is the same with any application, since I got a new update 23.5.A.1.291
https://postimg.org/image/6lajxyjch/
https://postimg.org/image/ocm6ceyr5/
https://postimg.org/image/deawu8a5t/
https://postimg.org/image/7rejwr7n5/
