Yuneec CGO3 video camera
Xperia z2 connect but in 10 s lost, connect and lost......
Try with friends xperia z3 and z5 works good.
Have any ideas
Android 6.0.1
kernel version 23.5.A.0.575
With regards
Liudvikas
Thanks for qiuck response, but in Safe Mode result is exactly the same
With regards
Liudvikas
Same situation, it disconnects from different routers at random times and even being next to the modem/router.
testing with colleagues Sony xperia z2, result same as with my phone
seems is technical defect of sony, next generation z3, z5 works properly
With regards...:(
after update Jun 28 2016, version 23.5.A.1.291 all working ...:)
Thanks
With regards
Liudvikas
My WiFi working, but when I open an application, it says Can't connect right now.
It is the same with any application, since I got a new update 23.5.A.1.291
https://postimg.org/image/6lajxyjch/
https://postimg.org/image/ocm6ceyr5/
https://postimg.org/image/deawu8a5t/
https://postimg.org/image/7rejwr7n5/
