i turn on the wifi connection, but when i didnt use my phone 1 hours, wifi will turn off automatically
so when i want use my phone it become laggy because i get all pending notification..
how can change the setting so my phone wifi keep turn on when i didnt use my phone??
anyone can help me??
Make sure that you haven't enabled Extended Standby Mode (Settings > Power management) and that your Wi-Fi policy is set correctly (Settings > Wi-Fi > Menu key > Advanced > Keep Wi-Fi on during sleep).
my Wi-Fi policy is set correctly (Settings > Wi-Fi > Menu key > Advanced > Keep Wi-Fi on during sleep).
but it still automatically off if i dont use my phone in one hours or more
You didn't mention anything about extended standby mode?
in my phone power management just have
stamina mode and low battery mode
and i didnt turn on that two
I'm sorry Stamina was the one I was looking for but if its not turned on and the Wi-Fi sleep policy is set never disconnect I suggest that you check out this topic.
http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104#U348104
Most interesting would be to check if this happens independent of network.
in faqs say i must update my phone to the latest update
but my phone is the latest update @ 11.3.A.2.13
i cant update it any more
yep, same as my xperia e c1505,
any solution yet?
