Hello, does anyone know how to fix the compass on the sony Xperia M? Mine does not work at all.
Have you attached any cover/case with a magnet? If yes, remove this cover to see if you experience the same behaviour. Otherwise, I suggest that you go to the dialer and enter: *#*#7378423#*#* > Service tests > Compass.
Hello, thank you for the very quick response. Indeed that has "fixed" the compass ( how embarrasing!). However it seems that the problem is the accelerometer. I will try recalibrating this.
Thank you again.
I have problems with my accelerometer too... it's not working properly since I bought my Xperia M (more than 1 year ago). It continuously changes its axis values even if it's layed down on a perfectly flat surface... I didn't give much importance to that, but after I downloaded a program who is based on the accelerometer's values changes, it has become a very annoying problem for me. What can I do to solve it?
Anyone else have our same problem?
