I had an update on my Xperia ray and upgrading to android 4.0.4 . after 2 days working , it suddenly didn't work.
I had checked the power battery and plug to charge .after getting charged ,nothing happend so I decided to turn it
to factory setting and the previouse android . I used the file which linke at your site.Now , the android version is 2.3.4
but the problem is ,The microphone doesn`t work any more.even when I turn on speaker.
Could you please give me a solution to solve this matter?
Sounds like a coincidence and there's nothing you can do except to contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
Dear Sir / Madam,
Thank you for your prompt action,
But actually , this link you mentioned is not useful for me during country policy of Sony .
I guess the only way remained is shooting it into garbage
