Xperia SP changing ringtone
TakoTako
Hi after updated to FW4.3 was trying to change my ringtone but seem it did not detect any file in phone or SD card memory. Using FLAC and MP3 but still don't seem to work which keep stated as unknown ringtone. Anyone had any solution? Many thanks.
7 REPLIES 7
profile.country.RO.title
_alexdon_
Try to play one of the files in walkman,see if the phone manages to play them.
alexdon
TakoTako
Yes did try on the default ringtone but not my other songs in my music file. Only default song works.
_alexdon_
Try to force turn off the phone:
http://userguide.sonymobile.com/referrer.php?region=global-en&product=xperia-sp#!Turning-on-or-off-t...
Remove the SD card and put it back in.Turn on the phone.
alexdon
TakoTako
Hi just try the force turn off but seem still same problem.
_alexdon_
How are you trying to change your ringtone?Are you changing from walkman directly or from settings-sound-ringtone-you have a little music note in right corner,tap on it and select from your own music.
alexdon
TakoTako
K think I found out the problem. You only can use sound picker and choose the song by tapping the top right music icon to select wanted songs. And can't done through file select. Kinda different from older FW. Super confusing for now.
Many thanks for the help reply. Appreciate your help.
_alexdon_
I am glad you sorted it out.Anytime.
alexdon
