Xperia SP not working
lacey
Apps installed on the phone keeps on crashing.
Photos that have been deleted are still shown in the Gallery.
Often stops working for about 2-4 seconds.
Have tried sony pc companion but problem still occurs.
Please advise.:smileysad:
Thank you.
11 REPLIES 11
Uliwooly
@lacey
Repair the phone with PCC
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
Jake-SonyXperia
Champion
Hi lacey,
Welcome to the community,
Please see the instructions below on how a software repair is done for PC or Mac.
Here's how to run the repair on PC Companion:
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
And Bridge for Mac:
1. Launch Bridge for MAC without the handset connected.
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
4. Select Continue on the following page.
5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
let us know how you get on.
lacey
Hi Jake,
Thank you so much for your reply.
But I have already tried repairing the phone through PC Companion but still the problem occurs. It didn't help. Slightly_frowning_Face
Any other suggestions? Appreciate your help.
Thank you.
lacey
Hi @uliwooly ,
Thank you for your reply. Unfortunately, PCC didn't fixed my phone.
Any other suggestions? Neutral_Face
Appreciate your help. Thank you.
Jake-SonyXperia
Champion
After you preform the repair are you restoring the handsets content or are you using it from stock?
lacey
Hi Jake,
What do you mean by using it from stock? Thinking_Face
I have also tried performing a factory data reset on the phone.
Uliwooly
@lacey
Repair the phone with PCC > do NOT install nor update any app > report back
lacey
Hi @uliwooly
Would you be able to advise or recommend any anti-virus scanner suitable for this phone?
thank you. Slightly_smiling_Face
Uliwooly
@lacey
I think @Thommo is the person to ask
