Hi all,
I just bought an Xperia U yesterday.
But for some reason I just CANT turn on Wi-Fi it always gives me an "Error" when I try to turn it on
and not further information about the error.
I have:
Sony Xperia U (ST25i)
Android version: 2.3.7
Build number: 6.0.B.1.564
If I try to do an update or something else through Sony PC companion or Update Service it says that everything is up to date.
Please help me!!!
Thanks
Regards.
Sorry to hear this. I suggest you try to repair the software (not the same as update).
In PC Companion, click on Support Zone > Start > Repair the phone software.
This will re-install the latest software which hopefully should fix your question.
What do you think about this forum? Let us know by doing this short survey.
No this doesn't helped to fix the problem.
Went to shop and got it replaced. I guess it was hardware issue on the phone itself.
Thanks for replay.
I have also an Xperia U. I have a similar same firmware also. (6.0.B.1.576) My problem is also the same. Tried to reinstall it several times (repair in Sony PC Companion) but nothing happened.
If I restart the phone and try to enable wifi i get the same error on enable. If i watch the wifi settings then i can see that it has no mac address. I am having wifi problems since updating to this firmware.
Plz Sony make us a new firmware with new wifi driver or roll out ICS but its kind of lame to have a smarthpone with buggy wifi.
I wanted to bring it back to the vendor for a replace but then my wifi started to work. It worked for 2 days perfectly and then i got the same error again. Watched in logcat app whats the problem and it says cant load wifi driver. For me it sounds like a firmware problem because if it would be a hardware it wouldnt work perfectly for almost 48 hours.
bro i have same problem if u got any solution than help me....
hiii..please help me bcz same problem in my phone xperia u st25i so tell me how to solve wifi error plzzzzz plzzzzzz plzzzzzzzzz
thanku
