I have EXPERIA E3 with a yellow warning triangle with an exclaimation sign in it. I know it is a warning but how do you find out what the warning is for, I have read the user guide but there is nothing there that tels you which is quite frustrating?
Does your phone boot up/start up and this is in the notification bar or is this when you try and boot your device
If this warning triangle is in your notification field, you should be able to drag it down to get further information about the warning.
