Hi
I have Xperia XZ premium
I upgraded to Android 8 last week,(Build Number: 47.1.A.3.254)
My Wi-Fi is being disconnected repeatedly in youtube,Online games and every app that wants a huge internet traffic
adabtiveSensor has become very sensitive, which is annoying
Battery consumption is higher than before(mostly Phone idle)
_________________________________
If others have the same problem please share with me
I'd suggest that you perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
Follow the steps given in blue links, and keep us updated.
Whats the solution?!! Does anyone know?? 😕
@Quester wrote:I'd suggest that you perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
nothing works above. really disappointed with sony. my last hope sony fix all in coming update.
@Trane wrote:Whats the solution?!! Does anyone know?? 😕
no solution. wait hope that sony will release a working update.
Thanks
But i did it and there was no change
Although, wi fi disconnecting improves
But i have this problems
Adaptive brightness is a known bug in this Oreo update and hopefully will be fixed in future updates, but your battery like and WiFi should improve after performing the repair process.
Yes im waiting for it
If they dont care about this problem for their flagship! I will change my brand
I love sony...
But im hesitant about it....
@Quester wrote:Adaptive brightness is a known bug in this Oreo update and hopefully will be fixed in future updates, but your battery like and WiFi should improve after performing the repair process.
Dear Quester
I'm glad to hear that about adabtive brightness
In the case of battery, many people have been dissatisfied with the poor performance of the battery after update
My phone has mostly double the battery life after the update, but still, it depends on your usage and apps installed. If you notice excessive drain after installing your apps, take a screenshot of your battery usage graph and post it here.
