Senaste programvaro uppdateringen så funkar inte alarmet det klickar om man ställt in en tid men går man in och testar alarm ljud funkar det
Latest software update so the alarm does not work it clicks if you set a time but if you go in and test the alarm sound it works
-GT
Po ostatniej aktualizacji do Android 10 nie działa alarm
The alarm does not work after the last update to Android 10.
-GT
After update My xz3 doesn't ring when I set the alarm.
Very irritating, Because it is such a basal function.
Tried everything I can think of but the phone doesn't alarm.
After the last update i have problems with the alarm, no sound and no visual on the screen... Anybody that knows something about this?
My Phone is a SONY EXPERIA XZ3 whith latest update 08.01.2020
I have kind of the same issue, when I turn of the alarm (not to snooze) it comes back in a minute, a couple of times. Really annoying!
My mobile got the same problem, turn off mobile and re-inset sim card mul-funtion. Pls fix the problem quickly.
+1. Snooze and dismiss malfunctioning unpredictably, every morning. I have of course restarted.
Same problem. I have set the Alarm and it just fails to go off. Nearly missed a flight.
This a is fundamental as I'm sure many people use their phone as their only morning Alarm.
Please find a bug fix as soon as possible.
Seeing as you are all from foreign parts(well, compared to myself in the UK), have any of you thought it may be down to the network customising your OS of Android 10.
Does anyone have a sim free phone running stock Android 10.
I've got a sim free UK model, running Android 10 untouched by network customisation, and it's fine, no issues anywhere.
Alarm clock works fine, snooze works fine, creator mode works ok also, as does Netflix and Amazon Video/Music, Deezer, Spotify, and a whole host of other apps.
Did you find a solution to this problem?
Та же проблема будильник повторяется много раз, пишет что повтор с 02:59, хотя на это время будильник не стоял. Ещё после обновления не срабатывает разблокировка телефона отпечатков пальца.
The same problem the alarm clock repeats many times, writes that the snooze is from 02:59, although the alarm did not stand for this time. Even after the update, the fingerprint phone unlock does not work.
gt
