Even if I in the Advanced sound settings have put the "Charge sound" to Disabled/OFF - I get a very high sound when I connect the charger.
Maybe it's the "Battery care" function that does it - but this function does not have notification settings.
Never any issue with 7 or 8 - came with the 9 update. Extremely annoying - especially for a (until then..) sleeping partner. Please fix asap, thanks !
XZ1 Compact
Same problem here. Android 9 (47.2.A.6.30).
After connection to charger, there is a noisy sound (like message), that smart charging was started.
Normal charging sound is quiet, I accepted this sound, but this new sound is very noisy and wakes all people around me.
Also this notification is special, unable to remove or disable it. At lease make it possible to remove this notification.
I want to use smart charging, but with this feature I have to disable it. 😞
