Sony Home Button
Artiz
Sony Home Button
Hello there
I want to learn about the home button which is the only point that comes with the Android pie
The ease of opening the back or background apps drawer with one-touch swipe left or right is embedded inside the pie Why is this not available in Xz Premium Software ?
Jonas
Master
Hi @Artiz, welcome to our forum!
If I understand correctly, you are looking for the gesture navigation feature, is that correct? We currently have not included gesture navigation in Android Pie, and cannot comment on future plans to add it. However, we will continue to listen to customer feedback and endeavor to evolve Xperia smartphones based on their needs.
I hope that answers your question! Slightly_smiling_Face
2 REPLIES 2
Uliwooly
@Artiz
I don't have this Xperia, but check on the homescreen long press anywhere > settings > Interaction > Enable swipe up, do you see the option?
Jonas
Master
