Battery Care Problem
Ro_Robert
Hello. I have a little problem with Battery Care. I have charged the phone, like 2 days at 23:30. Third day I get a notification from battery care that my phone will full charge around 07:00. All ok, but 2 days after, I put the phone at 22:40, and I didn't receive the battery care notification. So, i saw that, and after a second I remove it and put it on charge but still battery care doesn't start. First when I bought the phone, make the same problem, but back then I've connected the phone to the charger at the same hour, and after 4 days, battery care stops ...
Thank tou
*Sorry for my english*
1 REPLY 1
profile.country.PL.title
najodleglejszy
@Rob3r7it indeed seems like Battery Care reacts to quite narrow times for when you plug it in. still, you could try disabling and enabling it in Battery settings, I'm pretty sure it'll delete its trained data and will make it learn from scratch.
