Black screen during charge - ne reboot possible
Dorango
Hi everyone,
I'm coming to you with a random problem which I can't reproduce. Over the 2 past years, I had it about 2 times but I had to wake up at 5 am.....
Here's the explanation :
I'm putting my phone on charge, the alarm (The app AMDroid) is supposed to ring at 5 am but sometimes it doesn't. When i'm finally waking up, I'm finding the phone blocked. Black screen, no sound, no response to physical buttons (volume, power) or fingerprints. I'm forced to reboot it with the volume up + power off keys.
I really don't understand from  where comes the problem. I already had when I was using the regular sony alarm app and as I said above I can't reproduce the bug which is kind of embarassing when I have to get up early...
I hope you'll be able to help me,
Thanks !
2 REPLIES 2
profile.country.PH.title
MarlonUk1
all i could think is that the app is draining the battery overnight,
why dont you use the build in alarm instead?
Dorango
Hi nolramlb !
The phone is on charge when the problem comes so it's not the battery. Especially since I have to force the shutdown (which means it's not off). And finally, an app draining the battery would figure in the "battery consumption" option Grinning_Face
It's not the "amdroid" app neither because I also had the problem with the stock app.
And to answer your question, I need amdroid because I never have the same schedule everyday so I put it in google agenda with specific terms (morning, afternoon, night) and amdroid is automaticly settings the alarms (5am, 9 am et 9 pm) for everyday
