Hi there,
I have a problem with taking screenshots. As you can see, the boot menu is always visible on them. Running an XZ1C build 47.2.A.6.30.
Maybe I'm missing something but if you long press the power button you will get that menu:
shutdown
restart
screenshot
you can also take screenshots by press and holding power & volume down at the same time.
I know. But as you can see, the menu appears on the screenshot when using the first method, which it is not supposed to do.
Nevermind. It came to me last night, I've decreased the animation speed in the developer settings because I thought it looks better, that was the fault.
at least it wasn't something else acting up
