Hello;
Yesterday I updated my Xperia XZ Premium with android 8.0 and am facing the following bugs, in the Diagnostics Facts tool the System incidents, Subsystem Incidents, App Incidents, App not responding, interrupt calls, they all show "information not available", also the values for size memory are wrong (for example system memory is showing 68,72GB instead of 64GB), no mather the time I wait the values never change.
Also have found another bug, I have a SmartBand Talk and now the Xperia Phone Alarm does not ring / notify on the Smarband Talk, nevertheless the option is enabled in the SmartBand Talk app definitions.
It all was working fine in Android 7.1.1
Is anyone else facing the same problems? Any ideas for a solution?
Have you uninstalled the smartband and reinstalled it? It may have reset permissions
The permissions are all enabled and like in 7.1.1, and all the other functions on the SmartBand Talk seems to be working fine, its just the Xperia Phone Alarm notification/control.
I have the same problem with the alarm not notified on the Smartband anymore. If I reinstall the Smartband, will it keep all historical data or erase it?
Thanks
@Aleeo if you reinstall just the Smartband you don't loose any data because all the data is in the Smartband talk app, but don't bother I already reinstalled everything and the problem remains, I think it is a compatibility problem of the Smartband talk app or phone alarm app and Smartband with Oreo.
