Do not disturb menu displaying wrongly after Oreo update
munecito
The do not disturb menu is cut in half after the update, looks terrible.
The slider is also cut.
I have tried changing the font size and the screen display size but it is all the same. Screenshot_20171124-223436.png
3 REPLIES 3
profile.country.PL.title
najodleglejszy
@munecitoyeah, it looks like it's a bug that affects all Oreo devices and needs to be fixed by Google. Nexus and Pixel devices suffer from a similar bug: http://www.androidpolice.com/2017/08/24/not-disturb-toggle-invisible-android-oreos-volume-controls/
stanlykubrick
Contributor
Try this...turn off "Do not disturb" along with volume controls.
Here is how to do this:
Go to Settings > System > System UI Tuner > Do not disturb > Toggle OFF "show with volume controls"
Please KUDO if I was able to help!
munecito
Yes I have that activated but the menu still looks cut in half.
It is more of a visual bug than a functionality. I am able to toggle the slider as it is and I prefer to use the screen slider than to hold the volume button until it goes all the way down.
Thanks anyway.
