StudioMad
Hey Google
Since update I can't enable the assistant hey Google. If I switch on it gives a something went wrong message
10 REPLIES 10
IamNic
Hello @StudioMad,
which phone do you have exactly?
Have you tried to force-closing the app or deactivating then deactivating it again?
- Nic
profile.country.DK.title
Sturmi
I can enable mine, but it turns off shortly after by itself, i tried everything including changing laguage settings...so annoying. And it also wont work from lock screen even it is enabled in settings.
Xperia 1 ii
Jess.09
Specialist
Did you try to adjust how sensitive Google Assistant is to “Hey Google"?
You can try the steps in the following link: https://support.google.com/assistant/answer/9712065
ROBYER1
Take a look at my thread about this too, I have escalated this to the Sony Technical Support team and am persistently chasing this issue.
I bought a brand new XZ3 this August so am not pleased the pre-installed software misbehaves like this on Android 10, it's unacceptable.
https://community.sony.co.uk/t5/xz-series/xz3-android-10-unable-to-turn-on-hey-ok-google-quot-someth...
CosmicTomato
Specialist
Have you tried troubleshooting the device?
ROBYER1
Troubleshooting in the Sony Support app? It's just a readme guide without helpful information on something like troubleshooting the built-in Google Assistant. The microphone is working fine for calls and if I manually open the assistant using the home button on the XZ3 it picks up voice perfectly.
Already factory reset, software repaired using Xperia Companion, using safe mode to uninstall Google app updates and delete Google voice match data + enrolment on my Google account.
I went for a drive earlier and it was an absolute pain not having the hands-free Google Assistant working there, truly a health and safety hazard. I am still waiting to hear back from the Sony specialist team and the Google specialist teams looking into this, I can't use this phone for the foreseeable without the hands-free working, it's not even that old of a phone!
CosmicTomato
Specialist
Hi @ROBYER1 I know you've tried every other possible solution they have out there, pardon me but I was asking about @StudioMad 's issue.
Sturmi
Yep pretty much same here, and the issue will probably never be fixed.
Its a shame the support and fixes seems to be lacking, like patch info as well, and the no ASHA support for hearing imparied.
I love my Experia 1 ii but the lack of fixes and a feature like ASHA is bloody frustrating to say the least. Especially when one payed a big price for a flagship phone..
CosmicTomato
Specialist
Guess it's a good thing Google featured the accessibility feature on any Android device.
