How do I enable roaming on SIM 2?
Antloh
How do I enable roaming on SIM 2? The optionis grayed out.
Tags (1)
Antloh
Found the way - have the set SIM2 as the preferred SIM for mobile data in Dual SIM setting, then turn on the data roaming option in Mobile Settings.
A two step process. Poor UI design.
3 REPLIES 3
profile.country.PH.title
MarlonUk1
have you tried switching the sims?
Antloh
MarlonUk1
nice, can you click on your comment as the answer, this way other people can see how to do this with their devices,
also you can give this as feedback for sony by emailing them Local support
