Lags problems (bluetooth)
Marioss
Hi, i have problem with bluetooth connection playstation dualshock v2 and my xz premium dual.
When i play for example GTA SA there are lags like - when you want to turn left on crossroad your car turn left, but when you stop pushing this button on dualshock, game still thinking you pushing this button ( this problem is for 2 seconds).You can try it. And this problem is also in some other games.
How can i fix it ? Or i must use cable for it (because bluetooth is bad for great synchronization ?)?
Next week i will try on my phone remote play on ps4. Is there same problems with bluetooth ?
Thanks for any solution
Marioss
Hi, again apologyze about it. Problem was with dualshock. I try new one and all is ok ✅
1 REPLY 1
Marioss
