Latest system update
CEP1
Latest update has completely messed up my Phone - my snooze button only allows 1 minute, the alarm will not turn off even if turned completely off. The sound on apps, eg. FB, is on eventhough turned off. The phone is stalling when navigating... Anybody experiencing the same?
8 REPLIES 8
Heidi93
Nice to see I'm not only one.
Alarm keeps ringing even if I turn it off.
Some app notifications comes even half hour later.
Coxy73
My hotspot turns itself off 10 seconds after I turn it on.... Aarrrrgghhhhh
Jupke01
OriginalRingtones are gone no sounds for apps for weather , WhatsApp,mails.
SKSteg
Got the same on the alarms, can only really turn it off after unlocking my screen and pulling the notification menu from above down and selecting to ignore. Have to do this twice though as if there is also a second ghost run of the alarm.
Also some apps keep giving me old notifications that I already clicked (mostly Facebook ones)
And (maybe unrelated) having trouble keeping connected with my WiFi been a longer time issue (from before last update)
Same with keeping an open connection with my provider (T-Mobile) so people can't reach me anymore until I reestablish the connection (also no notifications on missed calls)
Jupke01
It is n very bad update, fingerprint is slow ,Slow working in general, ringtones are disapeerd, allow of apps is not esay to get in the system before it wash easey to give rights to apps.
Need an update for al these things wich are not good
Kind regards ,Joop
Keenjau
Must be the worst OS update in smartphone history, wonder how Sony does react to this mess.
Maybe the XZ2 is just too old for A10.
Kobusven95
I am experiencing most of the problems mentioned.
Battery drain fast, phone overheat, apps sloooow, fingerprint reader unresponsive, when I go back to the main screen it seems that the screen turns of for a millisecond or two, alarm that rings twice... Please Sony - fix this. I really liked the phone upto now. My wife have the same phone, and her phone is also slow and fingerprint reader is responding very slow.
SKSteg
I got most issues fixed with a software repair (remember that its almost a factor reset, so secure your data first), so alarm works normal again, fingerprint is fine, batterydrain is less again but still more then before.. Thing is though that the connectivity is still garbage.. I already we't to my provider to get a new simcard but that didn't help.. Says I can't connectie with the lte network, 3g network does connect but low on connection points and 2g is there.. But all still doesn't let me receive incoming calls (I'm in a city so cellservice is good on Samsung for example on samen provider)
