Notification Problems
kiiiii
I've been experiencing a problem everytime i copy, delete, or move files in file manager.
whenever i do the said actions the automatic notification that shows the progress does not close whenever the task is completed and sometimes it remains stuck and i cannot even close the notifications. what can i do to solve this problem?
1 REPLY 1
profile.country.PH.title
MarlonUk1
it usually lags when you modify large amount of files , especially if moving from internal to sd or from within sd card itself. try to wait it out, it would usually sort it self out.
try to modify ( copy pasting moving) small batches of files
