1 : Light sensor is still too sensitive ,Screen brightness is very easy to suddenly big and small (this problem from the September version there, I have feedback many times,please fix it!!😖)
2 : The battery is still not durable, an hour spent 20% of the electricity in wi-fi network environment。(In the 7.1 nougat version, the screen time is at least 3.5 hours at 60% charge)
Battery charging time is a lot longer than nougat version ,too slow。
System first run too much RAM… sontimes the system occupies more than 2G…
3: In the second menu I can not manage icons, such as integrated together… Did you forget to add the options?
Even though I connect the phone with PC Sony Common…
These ptoblem still exisy😭😭
The Phone Firmware area is Hong Kong, G1842,74.1.A.5.51。
and new bug
This problem does not exist in the nougat version, the album is still the latest version.
I hope you will fix these problems as soon as possible
Thank you!
My biggest issue after update is that some apps dont't run in background. Let's Say Facebook messanger is not connected to internet untill I open it. So my messages don't Come with any notification untill I open the app again. This is very annoying... Is there any solution for that?
about 4k hdr video screenshot i found something else
play the “xzp phone come with 4k vedio” no matter vedio app or mx player
it happened like this
however when i play anther video like 1080p or shot 4k vedio by xzp。It 's normal!
try this
Settings → app¬ifications → app info → facebook → battery ,check "background activity " on or off …
Ok, it was ticked as it can work im background. I have also added exception in settings that it doesn't have to Save battery. Maybe that will help. I will give it a go for few hours and See how it works now.
Chcecked. Still the same. I have also wrote to fb highliting this problem few days ago, but I still think it's something to do with software update as this is the time when I started having problem with it.
@Avril wrote:about 4k hdr video screenshot i found something else
It seems to me this somehow relates to DRM protection. I couldn't play this video on a PC also, it looked too dark. Or this may be due to HEVC main 10 encoding that is not supported widely yet, I'm not sure. It would be interesting if someone could play this video on a PC or another device.
something wrong with your settings. i never had this issue. check if u have your stamina mode on.
I didn't unlock it:smileyhappy:
ehmm… i didn't turn the starmina on ,are u update to oreo the 5.51 version?
