Unusually large folder
I have just updated my Xperia XZs to android oreo. The folder size is unusually large. Isn't it meant to be an auto fit to the number of icons in the folder. Please fix the issue.
It is normal in Oreo. When you use Xperia Loops or Need for Speed Payback scheme you obtain nice effect in the background of open folder 🙂
I use the default Xperia launcher itself... Only the theme is applied.
