Phonepad xz1
Hasassin
Phonepad xz1
How can I get phonepad as my default keyboard. No problem with z5, but I can't find it on my xz1
Duri
You can install the Xperia keyboard from Google Play.
Was one of the first things i've done on my XZ1.
2 REPLIES 2
CameronT
Champion
Hi @Hasassin, welcome to the community.
The Xperia X series of phones do not use Xperia Keyboard, which your Z5 did. Instead they use SwiftKey. SwiftKey however does not support the phonepad keyboard. You will need to look for an alternative keyboard from places such as the Google Play Store to find one that suits your requirements. Slightly_smiling_Face
Duri
