Screen too much sesitive
manolei
3 REPLIES 3
Uliwooly
@manolei
I'm sorry to hear that but the only option might be to apply a glass screen protector
AlexGuan
There are 2 ways to do it:
Wipe the screen with a wet towel or a wet tissue to remove static electricity from the surface.
Restart your phone, if it doesn't work, you can only send it for repair or change your phone.
Stick a tempered film, set the moving speed in the input method.
profile.country.US.title
Qatrium
@AlexGuan @manolei
There are some reports from many users that the latest firmware (ending with .265) has fixed this issue. Hopefully, you can confirm it did with your problem too.
