- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Status bar randomly disappears
The issue seems to only solve itself after restarting the phone, but then again after a few hours the same issue happens.
As you can tell, it's quitr annoying.
Is there anyone else having this issue? I'm running android nougat.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same issue too, I haven't figured out what caused it or when it happens, but yes, it does happen in the homescreen, and from what I can tell, only in the homescreen, but once I enter an app, the issue apparently stops.
Note: I'm running Android 7.0 too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I haven't been able to recreate the issue in safe mode yet, but I do not know what caused this bug in the first place. I'll continue to try and figure out that may have caused this bug, and see if it happens in safe mode.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dear Sony Team, this Bug is known in the Xperia Home G+ Comminuty since weeks. This is a bug between the latest Google app and Xperia Home. There a working for a fix. We cant to anything except rotate the phone in landscreen and back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Vadim_BenKatz
Your issue is due by a bug between the Xpeia Home 10 launcher and the latest update of the Google app.
You must disable the Google Now pane in the setting of the launcher or disable totally the Google app. Then clean manually the cache and after a reboot the status bar will works perfectly as before. Also the soft buttons of the navigation bar return to change (in homescreen) according to the theme used.
If this resolve your problem, check this as solution. :smileysmileythumbsup:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi everyone, I have some official information. Thank you everyone who noted it in the thread here.
- Software version Androidâ„¢ 7.0 Nougat.
- Google Nowâ„¢ is enabled. This is enabled by default in Xperiaâ„¢ X Compact and Xperiaâ„¢ XZ.
- Googleâ„¢ app version v6.11.13.21 or later.
- Long press on an empty area of your application Home screen, then click Settings.
- Find Google Nowâ„¢ and disable it.
- Reboot your device.
