Very weird camera app bug
Magaticosando
the camera app doesn't show anything but it still can take shots
I've linked this post with a video of the problem in the first comment
2 REPLIES 2
Lord_viridis
Sounds like a possible corruption in the code for live view in the camera app.
You can try:
Going settings/ app/ camera and clearing data and cache.
If this doesn't work
Settings/ apps/ camera and on the top right, three dots/uninstall  updates
If that doesn't work
Boot into safe mode (hold power button, then hold down power off until it says rebooting into safe mode)
See if it works.
If works - a 3rd party app is stopping camera functioning correctly, uninstall apps that use camera and retest in normal mode.
If not works- backup your data in Xperia companion and then perform a repair installation.
Tommy_Deer75
After latest updates for Xperia XZ2 compact, Phone changed very unstable. Camera worked totally bad. From Backcamera taken shots doesnt appears anywhere on the Phone. Selfiecamera instead worked. Phone gets freezing moments during sitessurffing and restarted by its ownway continuesly. Nothing those previously named happening doesnt appears earlier. All started after latest updates.
