I'm using default Sony Clock on my device and I like its look and feel pretty much. However, at the moment, I'm missing some features here... I would like to use e.g. UTC time in parallel to the local time. But the functionality of the clock seems to be very limited here...
1. There is "World time" tab on the clock app. However, I cannot setup "UTC" here. I found a"durty" solution using Iceland/Reykjavik. Since it is GMT time with no summer time, it is the same as UTC. However, I don't see the reason to comlpletely ignore the UTC option.
2. I cannot find the way to use the clocks, which are set up on "World Clock", in any other place. I would like to see the UTC time on home screen widget as well as on lock screen clock. However, there is no way to do so.
3. If you are on a travel, Google Clock provides a nice option to display "local" as well as "home" time. It is also missing on Sony Clock.
Is there an easy way to get this functionalities working? Or is it easier to find a third party app featuring all this?
@CuporaI think the easiest way would be to look for an app that suits your needs in Play Store. there are dozens of world clock widgets in there.
