My battery goes so crazy so I did go to battery usage and I found that Xperia Intelligence Engine takes the most battery drain after "Phone idle" and it stayed active while in background for 1d4h. Smart backlight control is off.
Any ideas for how fixing the problem and what is the source of it?
Thank you.
