XZ proximity sensor issue
ashokgk
I have few issues with my mobile. They are as below :
1) The proximity sensor does not work properly. I make a call and the screen goes black. Now the screen does not come back on. I have to press or wipe the proximity sensor few times to get the screen to display.
2) In order to fix this issue, i tried to take a back up of my mobile and do a software reset. But, taking the backup is not successful. I have updated the software on mobile and laptop. I use a macbook.
Because I couldn't take a backup, I am unable to do a software reset.
Now, after reading all this, please give me a good solution instead of saying :
1) try safe mode - i tried and it behaves the same way in safe mode also.
2) do a software update or factory reset. I can't do it as i cannot take a backup.
3) can't give to a service center without taking a back up.
Please give me a solution apart from all these.
I live in Ameerpet, Hyderabad. If you are suggesting a service center ,please suggest one near by.
Thanks,
Ashok
Tags (3)
0 REPLIES 0
