Hi there,
My new Xperia Z Ultra is marketed as supporting ANT+. I bough this phone because of this feature as I would like to use it for cycling to replace an aging Xperia Active.
It seems that ANT+ does not work on the Ultra. How do I get this working?
I got this working with the latest update. Bluetooth must be running. I'm loving it running IPBike for cycling.
Indeed it does support ANT+
http://www.sonymobile.com/global-en/products/phones/xperia-z-ultra/specifications/
Connectivity and communication
You can find info here
and here
http://www.thisisant.com/consumer/ant-101/activity-icons/?ant/ant-interoperability
Don't forget to give Kudos
Thanks. I know it has ANT+ and i know how to use ANT+, been using on my Xperia Active. BUT it has not been enabled in the firmware of the Xperia Z Ultra. Installing the ANT+ radio serice has no effect.
I think Sony has released the Firmware a tad to early, as the Sony Xperia M has the same issue.
Glad you got that working Colvil, I believe we spoke over on Whirlpool. Please do let us know how it goes when used for this with the bike as we don’t hear much about the ANT+ usage.
What are your thoughts about this forum? Let us know by doing this short survey.
