- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Why is not working on my z? even i already check to automatic but still old time showing on my phone. i tried to change any sim but nothing. but i have a signal and working fine. how can i fix this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Been wondering how your phone knows when you've changed time zones? If you've ever poked around in your phone's settings menu, you've likely come across the date/time settings. And that's where you have the option of either using "network-provided values," or setting the time manually. Chances are your phone's already set to use the network time -- in other words, your carrier and the cell towers tell your phone what time it is, and which time zone you're in. But if not, here's where you correct that.
For those of you with GSM phones, this also works when roaming overseas. Hop off the plane, turn on your phone, and it automatically adjusts the clock to wherever you happen to be.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That functionality doesn't actually come from within the phone or by the phone finding your location. The clock is set based on the time signals from the cell towers of your carrier. If you are having issue with the time not updating, it is likely because
1) you either do not have cell service.
2) the carrier you have is bad and doesn't have the time signal set up right from the towers to your phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
its okay now
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
