[Bug] Distorted thumbnails (possibly with upgrade)
Shahzeb1
Hello,
I recently purchased Xperia ZR, and it came with stock Android 4.1.2.
It notified me of updates sequentially to 4.2.2, 4.3 and then 4.4.2.
I installed all the system updates as well as the updates for Album, Walkman, etc.
Only after all the updates did I notice that the thumbnails in Album, Contacts or the contact pictures on notifications are distorted.
But this is completely random, one image might be distorted at a time, but appear clear other times. I have not seen this issue with full images, but due to the randomness I cannot be sure.
Since I didn't spend much time on the phone prior to updates, I'm unsure when this problem was introduced or if it was there since the beginning.
I have attached snapshots showing the issue in Album and in Contacts.
Please suggest how to fix this.
Shahzeb1
I had tried without the SD card as well. This issue was seen for images on Phone memory as well.
Anyways, the seller refunded the amount :smileyhappy:. Might have been some hardware issue.
Thanks for the reply. Cheers.
5 REPLIES 5
Shahzeb1
I downgraded to 4.3 and still see the same issue Slightly_frowning_Face
Also, its not just thumbnails but sometimes the wallpaper becomes distorted as well. Crying_Face
I don't understand how it could be a hardware issue, as only a particular image is distorted and the rest remains same. Also, only specific images are distorted. Face_with_rolling_Eyes
I do not have manufacturer warranty, so I'm avoiding taking it to the dealer as it would take weeks before I get the phone back.
Somebody please suggest what could be the reason and/or solution for this.
Thanks
profile.country.RO.title
_alexdon_
Try settings-apps-all-media storage,force stop and clear data.Restart.
alexdon
Shahzeb1
Already tried. That doesn't help.
And the issue remains even after upgrading the firmware.
Rickard
Master
Hard to say what could cause this. Do you have any SD-card in your phone and if so, have you tried to remove it? Perhaps the phone is having problems reading the files.
Shahzeb1
