Sorry to hear that you're having issues with updating our apps. I will forward this internally for investigation.
I also missed updates once, bat later found them under Update Center/"press three dots"/Manage updates. Check it.
i have the same problem
same for me no updates and can not find the new movie maker
Same issue with me.
After repairing the phone using PC companion, I cannot get the update center to find the updates for the apps. Our only option is to ask someone with the updated files to pull the apks and upload it for us.
