Can't update through PC
P_S_P
I received mail from sony saying that i've recieved an update 14.6.A.1.216 but when i check through pc. It says that i already have latest version 14.6.A.0.368.I'm from india.i think that update is for other country.what do you think.Give me some suggestions !
profile.country.US.title
Qatrium
You don't need to root to flash newer firmware directly by Flashtool and XperiFirm. I do this frequently so I don't wait for my customization update to be released. If you are too excited to get this update, head to XDA-developers.com and read some guides about flashing firmwares, should be easy and straight forward. Root gives you more control on system files and settings, but I don't suggest doing it if you're not too comfortable with messing with your phone as it might brick eventually.
12 REPLIES 12
Phy
Legend
Legend
Contact Sony Xperia support it could be an issue with the server.
http://support.sonymobile.com/global-en/contactUs/
P_S_P
I've tried it.they said that there's problem with my Internet service provider.but my internet is working fine.they told me to check it in 2-3 days
Phy
Legend
Legend
That doesn't make sense, maybe they didn't understood the issue, you have the latest update, you can also check
1. Settings
2. About phone
3. Software update
P_S_P
OTA update isn't available.
Qatrium
@P_S_P
Just keep checking on PC Companion, sometimes servers get overloaded by the amount of people updating at the same time.
To make sure, do you own more that one Xperia? Did you flash a different firmware recently?
P_S_P
@Quester.I only have one device.If this kind of service they'll provide i'll be thinking to root my device. What do you think ?
Qatrium
P_S_P
Thanks for you support .
P_S_P
If i root my phone.after that i install the stock rom and unroot my phone.will i be able to install official OTA updates or i'll have to flash it through flashtool ?
