CPU Limit on nougat
Xperiaman007
CPU Limit on nougat
Why are 4 cores always stopped on New nougat firmware on Xperia z5 premium? Still issue that is not fixed on New firmware i dont know whats point on it when nothing New is added (vulkan drivers, manual control, New lockscreen etc) or problem fixed..
profile.country.RO.title
_alexdon_
Same discussion as on X compact, how did you check? Take a look here:
/t5/Xperia-X-Compact/Nougat-upgrade-lowered-cpuclock/td-p/1187152/page/2
alexdon
69 REPLIES 69
_alexdon_
alexdon
bullfrog669
The 4 A57 cores are not disabled, they are just offline to save battery.
When have you ever experienced lag in everyday use? Never, that's because A53 cores are sufficient for that. That's the point of 2 processors, slower one is on always, powerful one, when needed. And Antutu is probably on blacklist from Sony, so people don't experience overheats, which is alright, since Antutu shows nothing at all...
Look at this(mine) SS. All 8 cores were active at some point.
So stop on Sony's head and use your brains. thumbnail_Screenshot_20170215-224956.png
Lord_viridis
Give the man a beer.
Big.little has always been like this and I'm amazed that people still don't fully understand that at some point fast cores will be disabled.
chrnodroid
The "4 core disable" is just a unfounded rumor. And benchmarks is best to avoid using them.
Nice work Sony!
The only missing feature is the new Manual Controls of the camera app and we seriously need it.
martinmrmus
Contributor
Why Sony have you disabled 4 cores after Nougat update? I think we paid for 8 and ni for ridiculous 4!!! This is over lone how Sony acts with its customers!!!
benimnetz
Why do you think that this has happened?
martinmrmus
Contributor
To of people and force them to buy new phone. Nothing more, nothing less...
ytheekshana
They are completely disabled. Run the Stress CPU app from the store.
Then the app will use 100% of the CPU, but still the 4 cores are not used.
Lord_viridis
Or... Run an app that utilises nougats api's and see that they are not disabled, or stop using benchmarks to see if Sony "switched off" half your cpu which would make your system sooooo slow you wouldn't need a benchmark to prove it.
