Developer Options
Snibla64
Developer Options
I want to make my z1 "stay awake when charging but can't find how to access the "deve"loper options" section in settings. Can you assist please?
Hampus
Champion
You can enable developer options if you go to Settings > About phone > Tap "Build number" 7 times.
2 REPLIES 2
Hampus
Champion
Snibla64
Brilliant! Thanks for this and the ultra speedy reply ๐Ÿ™‚
