ERROR - capacity for NFC services full
tj2312
Hi there. A few days ago, all of a sudden, I started getting an error: capacity for NFC services full. After browsing the web for solutions I tried everything suggested (mainly uninstalling banking apps which I wasn't using anyway) with no result.
The phone I have is xperia z3 dual sim, and the error occurs when I am activating usually inactive sim card in slot 2. After that it appears every few minutes (usually when doing something with settings->apps) with NFC off.
I tried uninstalling apps, safe mode - no resutls.
I haven't installed anytnihing new, haven't had that problem ever ('ve been using the phone for 3 years). Stock 6.0.1 android
My question is: is it a known problem, are there any solutions to it. Thank you.
Here's the screenshot:
https://s29.postimg.org/k5z1dygjr/Screen.jpg
15 REPLIES 15
NeoBeum
Enthusiast
Android Pay?
tj2312
I don't think I have android pay. Would you mind telling me where to look for it to veryfy if it's there?
I also do not have google account and google playstore account and I'm not logged in into any google services.
NeoBeum
Enthusiast
Turn NFC On, then it's settings menu will appear in settings, NFC will have some settings in Settings-Wireless and Networking, and Tap and Pay should appear in Settings-Device
tj2312
Thank you. I did find it. The thing is, there's not much one can do about it. Is there any way to disable it because settings only list two options "payment default" and "use default" non of wich has an option to turn it off.
The apps section also does not list it.
Is there any way to disable the suspected culprit?
NeoBeum
Enthusiast
Not without rooting...
, there is Android Beam too, a NFC Service
NeoBeum
Enthusiast
Do you actually use NFC at all?
tj2312
Sorry for a late reply.
The error occurs even with NFC switched off. But to answer your question, yes I do use it all the time manely to transfer photos and videos between my and my friend's phone.
Maybe one of sony official staff members has any say regarding that problem. Thank you.
NeoBeum
Enthusiast
Android beam would be the only service you're using
SNair
I have been getting constant popups for "Capacity for NFC services full" dialog box. fairly random.. almost every time i pickup the phone i get this dialog box pop up.
then if i press CANCEL, it will dismis
if i press "Change services" i go to another sceen that is just a blank white space with title "Change available services" "capacity used for nfc services is 115$" CANCEL (OK greyed out)
I CANNOT GET RID OF THE POP UP DIALOG BOX .
Someone Please help.
Tags (1)
