Flashing using Flashtools will not delete the DRM keys - Unlocking the bootloader will - HK has banned I believe some Google apps - If your bootloader is locked and you know how to use Flashtools then visit XDA
Edit:
If your bootloader is unlocked then Flashing a stock .ftf firmware file will not re-lock your bootloader nor will it restore your DRM keys - Once they are gone they are gone for good unless you achieved root and backed up your TA partition
Edit:
Thanks for the reply. I'll look at that this weekend.Looks a better option than going the EMMA route. Google apps are working fine on the phone, so may leave it for now. Thanks again Thommo
