Google Chrome not working after update
kaká
I just updated my phone today (sony xperia z), since then my phone has been slower than it was and also Google Chrome is not workin, it keeps sayin. 'unfortunately chrome has stopped'.
Please help.
Thanks
Uliwooly
Settings > apps > all > chrome > uninstall updates > clear data > restart your phone > install the latest chrome udpate
10 REPLIES 10
Uliwooly
blackmagic
Remove the chrome updates from the application manager and try to install again delete all data
kaká
Cheers guys I appreciate your help, I done exactly what you said (both of yours same). Google chrome is working. Thanks for the quick reply.
Kind Regards
kaká
Sorry one more thing I forgot, what do I do about the slow performance of the phone after the update.
blackmagic
Try to repair with the PC Companion software
kaká
ok, I'll let you know how I get on.
kaká
Hello mate,
I tried to repair it but I didn't. The guide you gave me was perfect and easy to do but I had to do a backup first. So when I tried, I couldn't finish the backup process coz it took very long (3hrs)...it's too much.
Nevertheless I deselected notifications for lots of apps and force stopped some, now it's running ok. I'll let you know if anything changes.
Regards
