Help!!!!!!!!!!!!!!How to upgrade C6602 Rooted to v4.2.2?
HLinS
How can I upgrade my xperia z c6602 (rooted) to v4.2.2?
Plz guide me.
Can I use pc companion to upgrade for rooted phone?
Uliwooly
if your bootloader its locked and the update its available to your phone you can use either PCC or SUS to update your phone
11 REPLIES 11
Uliwooly
Uliwooly
or you can Manually update your phone to 4.2.2
http://talk.sonymobile.com/thread/124152
HLinS
Yes.My phone is bootloader locked.
Uliwooly
then if the update its available in your country and/or carrier use SUS or PCC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
HLinS
Thanks a lot.
HLinS
Can I use PC Companion to upgrade if the phone is {ROOTED}?
Uliwooly
yes you can, you can not use PCC or SUS if you have an unlocked bootloader, otherwise you should be able to use PCC or SUS
Uliwooly
I've answered that question 3 times, don't create new threads with the same question
HLinS
Thanks:smileyhappy:
