Is there any way to do a local search on the device? It seems like an obvious feature, but I'll be if I can find it.
You are welcome, please mark solution so it will benefit to others
Open Google search, press and hold home button... Select more ( Three dots on the bottom right corner )
Choose Settings - Click Phone Search - You will find options that can be added to your search...
Open Search bottom you have menus like Web Images .... Scroll horizontal to reach phone and you can search for phone...
Thank you for this information.
Not exactly user friendly to need to do this everytime.
