Podziel się wrażeniami!
I connected briefly to a Wi-Fi network at work.
Although I choose to forget that network, now my Wi-Fi stays active all day.
I even reconnected to the network and choose to remove it under Location-based Wi-Fi -> saved networks.
That also didn't help.
Anyone tips on how I can get the phone to disable Wi-Fi again at this location?
PS None of the saved networks from Location-based Wi-Fi is anyway near my working location.
Try clearing data for the app called Location-based Wi-Fi under Settings -> Apps -> All and then restart the phone and see if it helps.
If the problem remains, try updating the phones software using PC Companion.
