EzraAbozaid
many questions
hi everyone, first question: does anyone activate the xLOAD? and does it affect on sound quality or it just loader the speaker?
second: what is better for battery? activating the (adapt to lighting conditions) or set brightness to 40% ?
third one : when i play modern compat 4 it runs smoothly but in high quality places (like in mission 4) or when many enemies appear it lags a little bit so is that normal? my phone is xperia z
forth: i forgot to backup my files , so can someone pls upload the custom music and movies files?
Uliwooly
XLoud is only for the loud speaker
as for battery stay away from intrusive unnecessary apps
taskillers
task managers
antivirus
ram apps
battery apps
booster apps
it will be better to set it an a specific %
this lag will be something the game developer has to fix
this files varies per regions/countries
3 REPLIES 3
Uliwooly
taskillers
task managers
antivirus
ram apps
battery apps
booster apps
EzraAbozaid
ty but for the game is it not a hardware issue ? i mean is it bad optimized for all xperia z ?
Uliwooly
its not a hardware issue its a compatibility issue
