problem after service
RobbinB85
Ive had my phone on service, surprice, nothing is better except the cracked screen that is exchanged.
And now i have a ring when i hover my finger 1-2mm above glass, when i touch the glass it dissappear.
I managed to get the ring on picture, look at link.
https://www.dropbox.com/s/4e5u4xkzvtr5cpl/Screenshot_2014-09-12-11-28-29.png?dl=0
HussainQuadri
Contributor
The ring you see appears from Glove Mode being active. It usually shows that to register a touch when you are using the device with, well, gloves. Or in your instance, a slight touch on the screen which you can't feel.
Turn it off in Settings > Display and everything should be fine.
2 REPLIES 2
HussainQuadri
Contributor
RobbinB85
That was it.. Thanks ๐Ÿ™‚
