screen shot
Ruslikusyadi
screen shot
Did anyone can tell me how I can use screen shot at Xperia z ultra? Is Xperia z ultra have screen shot or screen capture menu?
18 REPLIES 18
agendus
Oh. Only from 4.4.2 can do that.
Hope Sony will keep this function.
Nizar1978
Press power button with volume down together for 1 second.
xtra
It is possible on latest kitkat 4.4.2
Hold power button for 2-3sec then popup with option
1)power off
2)air plane
3)take screenshot
Icon silent-vibrate-normal.
Pavandkkumar
Holding power button-> menu comes up-> select screen shot it doesn't works for me after updating my Xperia Z to 4.3 version... Before it was working fine please help
Pavandkkumar
Power button and volume down key worked for me thanks a lot
xtra
The easiest for z ultra and maybe all xperia version with Active Clipâ„¢ that accessible via small app launcher.find a small crop box like with 2 mountain inside.
p/s"EN not my lang"
Aizam
U can press power button ...the pop out menu will appear...select screen shot
moi17
@JoeYap wrote:
Alternately you can also open recent app, a square button beside home button. In it you will see the mini app list at bottom. There is one icon look like square with mountains in it is mini app for screen capture.
This doesn't appear when I press 🔲 as instructed.
Any ideas. Using power button is awkward and clumsy
Thanks in advance
Uliwooly
@moi17
You have 3 options
1 press and hold power & volume down
2 long press the power button > screenshot
or
3 download a third party app to do so.
